Google Workspace SAML integration
To begin with the integration process, Login to the Google Workspace Admin Portal.
Step 1: Add custom SAML app.
  1. In the Admin console, go to Menu > Apps > Web and mobile apps.
  2. Click Add App > Add custom SAML app.
  3. Enter App Details
    • Enter the App name and Description.
    • Optionally, upload an icon for your app.
    • Click Continue.
  4. On the Google Identity Provider details page, Download the IDP metadata file. This file will be needed later in the Enpass Admin Console to complete SAML configuration and then Click Continue.
  5. In the Service Provider Details window:
    • Enter the Entity ID and ACS URL (Assertion Consumer Service URL) as provided by the Enpass Admin Console during setup.
    • Select the checkbox for Signed response to ensure the SAML authentication response is signed.
    • Set the Name ID format to EMAIL and the Name ID value to Primary email.
    • Click Continue.
      add custom saml app in google
  6. Map User Attributes
    • For Google Directory attributes, click the Select field menu and choose Primary Email.
    • For App attributes, enter Email as the corresponding attribute for your custom SAML app.
      map user attr in google
  7. Click Finish to complete the app setup.
Step 2: Enable User Access
All administrators of the Enpass Admin Console should be assigned to this application to enable SSO login.
  1. Click User access.
  2. Assign Enpass admin console users to the application.
