Okta SAML integration
To begin with the integration process, Login to the Okta Portal.
Step 1: Create SAML integration
General Settings
In the Admin Console, go to Applications > Applications.
Click Create App Integration.
Select SAML 2.0 as the Sign-in method and click Next.
Provide the general information for the integration and then click Next.
Configure SAML Settings
Copy the URLs from your Enpass Admin Console SSO settings and paste them in the Single Sign On URL and Audience URI (SP Entity ID) fields.
Set the Name ID format to EmailAddress.
Configure Attributes
In the Attribute Statements section, add an attribute for the user’s email:
Name format : unspecified
Value: user.email
Click Next to proceed
Feedback
No changes are required; simply click Finish.
Step-2: Complete SSO Setup
The new application will now appear in Active Apps under the Applications tab.
Click on Application.
Under the Sign On section, copy the Metadata URL.
Paste this URL into the SSO setup section of the Enpass Business Admin Console to complete the configuration.
Step 3: Assign Users to the Application
All administrators of the Enpass Admin Console should be assigned to this application to enable SSO login.
Go to Applications > Applications, select the app integration to open its settings page, and then go to the Assignments tab.
Assign Enpass admin console users to the application.
