Configuring Recovery Link Expiry Time in Enpass Admin Console
It allows Admin to define how long a recovery link remains valid after a user initiates a recovery request. By default recovery link expiry time is 2 Hrs.
How to Set Recovery Link Expiry Time:
  1. Access the Enpass Hub Settings:
    • Log in to the Enpass Admin Console.
    • Navigate to the Settings page.
    • Locate Enpass Hub section then click on Recovery.
  2. Change Expiry Time:
    • Click on Change Time.
    • Select either Hours or Days from the dropdown.
    • Enter the desired time duration.
      Change Expiry Time
  3. Save the Configuration:
    • Once you have set the desired duration, click Change to apply the settings.
